usg60w wifi and lan1 > a customer wiped one of their remote office routers
zigandzag
zigandzag Posts: 8 image  Freshman Member
After a cable outage, the customer not only power cycled everything but used a point to hard reset the router. They use wifi to update handheld tablets for delivery drivers. I used the wizard to set up the wifi but it shows on the home/monitor screen as being on lan1 but in expert mode it shows outgoing interface lan2. Can I save the startup config and change lan2 to to lan1 and import the new config file otherwise, I do not see an advanced mode when setting up wifi?
I see the following in the config file:
wlan-ssid-profile default
ssid Zyxel
qos wmm
security default
outgoing-interface lan2
bandselect mode disable
wlan-ssid-profile EZMODE_SSID_WIFI
ssid Greencastle
security EZMODE_SECURITY_WIFI
Is there any other way to correct this i.e. get wifi on the same network as the wired PCs on lan1? And, will it work ok?
    PeterUK Posts: 4,426 image  Guru Member
    Did you not have a backup config? if best to start over without the wizard and be in advanced mode.
  • zigandzag
    No backup… There was a backup 4-years ago when first configured but it was left at the site. Computers were changed, management changed, no one knows what password went to any old loggins. A "used-to-be" computer expert did the recent damage. I'm the garbage man they call when things have gone to crap.
    I am just down to the wifi issue. I have the sql server locked in dhcp, I established the vpn tunnel back to the home office…..Sorry, I will contact Zyxel directly. I was hoping for something for more like a yes or no- here's how.
