antispam works just with pop and stmtp ?
robertog
robertog Posts: 8  Freshman Member
Hello Support,
I'm trying to test spam email but It doesn't work.
I think it works just with pop and smtp. I can't use it because I use stmp with ssl and pop as well. I'm wrong ?
Please let me know.
thank you
roberto
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,798  Guru Member
    Hi @robertog,
    Yes, it works just with POP3 and SMTP.
    Zyxel Melen
  • robertog
    Hi Melen,
    thank you for your swift reply but really I hope as soon as possible with new firmware Zyxel can fix this bug. Almost 100% use pop and smtp email with ssl. No make sense block spam when no one use simple pop and smtp.
    Regards
    roberto
