Console stops working V2
PeterUK
USG FLEX 200H V1.31(ABWV.0)
So with the correct settings just under 24hr the Console stops working with PuTTY shows
Unable to open connection to
COM3
Configuring serial port: Error A device attached to the
system is not functioning.
Hi @PeterUK,
Can this issue be resolved by replugging the console from the PC connecting side?
Zyxel Melen0 -
Nope still same error
well looks like my USB to Serial Adapter died yet windows says its fine tested it to another device and same error so new one of them
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 125 Nebula Status and Incidents
- 6.3K Security
- 489 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 455 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
