ZYXEL EX5601-T0 - how to assign the same NAT forwarding ports to 2 lan IPs?
Hello everyone! I have a ZYXEL EX5601-T0 https://service-provider.zyxel.com/global/en/products/ethernet-cpe/ethernet-iads/ex5601ex5600-t-series
I can't solve this issue:
PC 1: assigned static ip 192.168.1.100
PC 2: assigned static ip 192.168.1.200
In NAT section I opened , for PC 1, ports 50100 and 50101 for TCP/UDP protocols
How can I do the same for PC 2? If I try to add the rule putting PC 2 IP, I am blocked by an alert cause of "open ports are linked to another IP".
How can I do?
Thanks a lot in advance!
AFAIK… it's not possible.
Router EX5601-T0 have on WAN only one port set (1-65536, TCP + UDP). So for ports 50100 and 50101 you can forward them only to one address.0
Router EX5601-T0 have on WAN only one port set (1-65536, TCP + UDP). So for ports 50100 and 50101 you can forward them only to one address.0 -
Thanks man!
depending on why you are forwarding ports in the first place you maybe don't need to. router keeps track of (tcp and udp) outgoing traffic and auto opens RTC ports from specified ranges for replies such as sip:10000-20000 ports allowed on receiving computer. So you may only need incoming port forwards if you have devices external to your 'home' network, so that such devices can connect. The BUT is that open ports are a security risk so security is needed to auth external dvices on random IP addresses. outgoing connections to providers are originated from your PC / server/ whatever, so should be whitelisted according to IPaddress or MAC.
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 299 Service & License
- 482 News and Release
