usg60w wifi and lan1 > a customer wiped one of their remote office routers
After a cable outage, the customer not only power cycled everything but used a point to hard reset the router. They use wifi to update handheld tablets for delivery drivers. I used the wizard to set up the wifi but it shows on the home/monitor screen as being on lan1 but in expert mode it shows outgoing interface lan2. Can I save the startup config and change lan2 to to lan1 and import the new config file otherwise, I do not see an advanced mode when setting up wifi?
I see the following in the config file:
wlan-ssid-profile default
ssid Zyxel
qos wmm
security default
outgoing-interface lan2
bandselect mode disable
wlan-ssid-profile EZMODE_SSID_WIFI
ssid Greencastle
security EZMODE_SECURITY_WIFI
Is there any other way to correct this i.e. get wifi on the same network as the wired PCs on lan1? And, will it work ok?
Did you not have a backup config? if best to start over without the wizard and be in advanced mode.
No backup… There was a backup 4-years ago when first configured but it was left at the site. Computers were changed, management changed, no one knows what password went to any old loggins. A "used-to-be" computer expert did the recent damage. I'm the garbage man they call when things have gone to crap.
I am just down to the wifi issue. I have the sql server locked in dhcp, I established the vpn tunnel back to the home office…..Sorry, I will contact Zyxel directly. I was hoping for something for more like a yes or no- here's how.
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
