How to enable MLO on non-Nebula nwa130be ap with latest firmware?
davidfi01
davidfi01 Posts: 17  Freshman Member
First Comment First Answer
If not using Nebula, and accessing NWA130BE through web interface, how do you enable MLO after updating to latest firmware (7.00(ACIL.1)C0) on nwa130be?
Best Answers
  • Zyxel_Kay
    edited September 2024 Answer ✓
    Hello @davidfi01
    Update 20240927:
    While we work towards implementing MLO in standalone mode, we'd like to emphasize that: The key WiFi 7 feature, Multi-Link Operation (MLO), has been supported on Nebula since July 2024 and we invite all users to try this new technology and provide feedback on your experience.
    Thank you for your follow-up question. I apologize for any confusion, but I can confirm that the timeline I mentioned is indeed Q3 2025 for implementing MLO in standalone mode for the NWA130BE AP.
    The reason for this extended timeline is due to the complexity of designing the profile object for standalone mode. This process requires thorough development and testing to ensure stable and optimal performance.
    We understand that this may seem like a long wait, and we appreciate your patience. Our team is working diligently to bring this feature to standalone mode while maintaining the high standards of performance and reliability that our customers expect from Zyxel products.
    In the meantime, if you require MLO functionality for your NWA130BE AP, we recommend using it in Nebula Cloud mode, where the feature is currently available.
    If you have any further questions or concerns, please don't hesitate to ask. We're here to help.
    Kay
  • Zyxel_Kay
    Kay
  • davidfi01
    bump
  • davidfi01
    bump
  • Zyxel_Kay
    Hi @davidfi01
    Currently, the MLO feature is supported only in Nebula Cloud mode for the NWA130BE AP. To use the MLO feature, we recommend managing your AP through Nebula Cloud.
    As for standalone mode, the MLO feature is still under development. We plan to introduce this feature in standalone mode WiFi 7 AP in Q3 2025.
    Kay
  • davidfi01
    Q3-2025??? did you mean Q3-2024?
    If 2025 - that seems like an awfully long time from now.
    D
  • davidfi01
    bump
  • davidfi01
    bump
  • Zyxel_Kay
    Hello @davidfi01
    Update 20240927:
    Kay
  • Zyxel_Kay
    Kay
  • TimoMF
    TimoMF Posts: 2  Freshman Member
    do you have good ones would progress can do and yours time-flat shorten konnen?
    Greeting timo
