Console stops working V2
PeterUK
edited January 2025 in USG FLEX H Series
USG FLEX 200H V1.31(ABWV.0)
So with the correct settings just under 24hr the Console stops working with PuTTY shows
Unable to open connection to
COM3
Configuring serial port: Error A device attached to the
system is not functioning.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,611 image  Zyxel Employee
    Hi @PeterUK,
    Can this issue be resolved by replugging the console from the PC connecting side?
    Zyxel Melen
    Nope still same error
    well looks like my USB to Serial Adapter died yet windows says its fine tested it to another device and same error so new one of them
