ATP500 and rekey time in phase1 for ipsec VPN tunnels
TasagoreSeibei
TasagoreSeibei Posts: 1 image  Freshman Member
Hi
I have a IPSEC tunnel, the other side is a Sophos device. We have intermittent disconnections and the Sophos guy says that it's due a bad rekey time. The remote log shows:
"Received IKE message with invalid SPI"
They have the tunnel configured in Phase1 for SA LifeTime of 10800s with a re-key margin of 360s, but I can't configure the second one setting in the ATP500.
Which is the default re-key margin for an ATP500?
Regards
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,320 image  Zyxel Employee
    Hi @TasagoreSeibei ,
    Let me clarify what you're asking:
    • For the Sophos device: They can set Phase 1 SA Lifetime of 10800s with a 360s re-key margin.
    • For the ATP500: You can only set Phase 1 SA Lifetime, but no re-key margin setting is available? Are you looking to confirm what the default re-key margin is for Phase 1 on the ATP500?
    Zyxel_Judy
    Untitled Image
