ATP 500 and Web Gui unusable
Ceccus
Ceccus Posts: 46  Freshman Member
I have an ATP 500 that is not directly exposed on the Internet.
Since this morning I can no longer reach the configuration web interface. It remains loading with Firmware 5.39 ABFU 1. And even some sites no longer load correctly.
Restoring the previous firmware version (5.39 ABFU 0) everything is OK.
To restore I used ‘debug mode’ by running the commands :
atcd 1
atgo
Probably an ATP200 alreo also has the same problem (but I will check this tonight)
Has anyone had the same problem?
Thank you and best regards
David
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,526  Zyxel Employee
    Hi @Ceccus,
    Restoring to the old firmware version doesn't delete the issue signature. Please follow the FAQ to upgrade the date code firmware, which will delete the issue signature.
    Recovery Steps for USG FLEX/ATP Series Application Patrol Signature Issue (Jan. 2025) — Zyxel Community
    We hope this guide will help you resolve the issue quickly and minimize any further disruptions. If you continue to encounter difficulties or need additional support, please do not hesitate to reach out to our support team at cso_security@zyxel.com.tw or leave a detailed comment here with your region(country), model information (S/N), and contact info. We'd like to have contact with you to assist and resolve the issue caused by the signature incident.
    Zyxel Melen
  • ESupport
    ESupport Posts: 23  Freshman Member
    edited January 24
    we had the same issue. Only now there is this post https://support.zyxel.eu/hc/en-us/articles/24159250192658-Firewall-Not-reachable-or-unresponsible-or-unable-to-boot-up .
    We upgrade only one partition in case the new version has any problems. How do i know which is the backuppartition? Trial and error is the answer. Had a Flex and 2 ATPs for now.
    Will there be an Signatureupdate that fixes this error or have i to recover any Box thats not reachable anymore?
  • BCC
    BCC Posts: 12  Freshman Member
    First Comment Friend Collector Seventh Anniversary
    I would recommend to temporarily disable App Patrol scheduled definition download until we know Zyxel removed bad definition. Your fixed devices will pull it again and go into the same unresponsive/rebooting loop.
  • Ceccus
    Thank you for your answers.
    I'll check the signature updates ... thanks
    With the newer Firmware it worked until last night.
    David
  • Ceccus
    Updating all signatures (including APP Patrol) with the old Firmware (5.39 ABFU 0) continues to work.
    Regards
    David
  • Ceccus
    this is one of the errors (Zyxel ATP 200) Firmware 5.39 ABFU 1)
    David
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317  Zyxel Employee
    Hi users,
    You can find the step-by-step guide at the following link:
    We hope this guide will help you resolve the issue quickly and minimize any further disruptions. If you continue to encounter difficulties or need additional support, please do not hesitate to reach out to our support team at cso_security@zyxel.com.tw or leave the detail comment here with your region(country), model information (S/N) and contact info. We'd like to have contact with you to assist and resolve the issue caused by the signature incident.
    Thank you for your understanding and continued support.
    Zyxel_Judy
  • Ceccus
    Still the same problem?
    I have restored to the old firmware version and everything works again.
    But what's going on?
    D.
  • Zyxel_Melen
    Hi @Ceccus,
    Zyxel Melen
  • Ceccus
    Restoring from the old firmware (the one you made available) solves the problem. After that you need to update the signatures again.
    I 've had to do it 2 times because the Patrol APP signatures were again not usable and were messing up the machine.
    I have been a customer of yours for over 15 years but this just won't do.
    D.
