Power adapter for Zyxel NAP303
Deewa
Deewa Posts: 2 image  Freshman Member
Hello Guys,
I bought a replacement power adapter for my Zyxel NAP303, but it doesn't work.
The adapter works fine via POE, but that won't do.
What power adapter should I get?
Best Answers
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317 image  Zyxel Employee
    Hi @Deewa ,
    The NAP303 supports two power options:
    • DC Input: 12V DC, 2A
    • Power over Ethernet (PoE): IEEE 802.3at compliant
    Please ensure you use either a compatible 12V/2A power adapter or an 802.3at-capable PoE switch/injector to power the device.
    By the way, please be aware that the NAP303 model has reached its EOL status. For optimal performance and support, we recommend exploring our current switch offerings here:
    https://www.zyxel.com/us/en-us/products/wireless
    Zyxel_Judy
    Untitled Image
  • FabioBasso
    FabioBasso Posts: 13 image  Freshman Member
    Zyxel Certified Sales Associate First Answer First Comment Third Anniversary
    According to the manual, the NAP303 consumes 17.04W, so you need to use an 802.3af PoE injector.
    Name - IEEE Standardard - Max. power per port
    PoE - IEEE 802.3af - 15,4 W
    PoE+ - IEEE 802.3at - 30 W
    PoE++ - IEEE 802.3bt - 60 W
  • Zyxel_Judy
    Hi @Deewa ,
    Zyxel_Judy
    Untitled Image
  • FabioBasso
