Replace ATP200 with other ATP200
cBoz
cBoz Posts: 5 image  Freshman Member
HI,
I need to replace an ATP200 with another ATP200. How to keep the same configuration? Is it possible to download startup.config.conf and load it onto the new one without reprogramming all the functions?
THX
Carlo
  • Vagabound
    Vagabound Posts: 49 image  Freshman Member
    First Answer First Comment Friend Collector Third Anniversary
    I think that someone from Zyxel support can clarify this.
  • Vagabound
    edited January 2025
    This is exactly what I would be interested in. We are replacing a USG FLEX 200 with a new USG FLEX 200 and can I transfer a still active iCard license from the old USG FLEX 200 to the new one?
    THX Vagabound 🤔
    PeterUK Posts: 4,446 image  Guru Member
    I'm not sure how the admin or any of the user names are encrypted would work you might have to set the password on new ATP200 and copy that line in config to the backed-up config to use on new APT200
  • cBoz
    Thx,
    What if I activate the new one with the same admin passwords and then restore the startup.config.conf file of the old ATP200?
    I recover all the rules?
    THX
    Carlo
  • Vagabound
  • Vagabound
    @PeterUK
    You are probably right, I looked at the config file in an editor and saw that the passwords are all encrypted. There is certainly a problem with this as it is no longer the same hardware.
  • electsystech
    electsystech Posts: 60 image  Ally Member
    First Answer First Comment Friend Collector Sixth Anniversary
    Yes, you can use the startup-config file from the old router to the new one and your firewall rules and credentials will come across.
