Replace ATP200 with other ATP200
I think that someone from Zyxel support can clarify this.
This is exactly what I would be interested in. We are replacing a USG FLEX 200 with a new USG FLEX 200 and can I transfer a still active iCard license from the old USG FLEX 200 to the new one?
THX Vagabound 🤔
I'm not sure how the admin or any of the user names are encrypted would work you might have to set the password on new ATP200 and copy that line in config to the backed-up config to use on new APT200
Thx,
What if I activate the new one with the same admin passwords and then restore the startup.config.conf file of the old ATP200?
I recover all the rules?
THX
Carlo
maybe this article can help:
Yes, you can use the startup-config file from the old router to the new one and your firewall rules and credentials will come across.
- 426 Beta Program
- 2.6K Nebula
- 163 Nebula Ideas
- 6K Security
- 345 USG FLEX H Series
- 289 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 261 Service & License
- 404 News and Release
- 86 Security Advisories
- 3.8K FAQ
- 82 Security Highlight
