IP range
If you need to double IP range, you can set subnet mask to 255.255.254.0
Then you can have from 192.168.10.1 to 192.168.11.254.
You will need to reconfigure all devices not managed from DHCP.
no the submask is what limits how many IP's you have.
I guess you can have LAN1 192.168.0.1/24 and LAN2 192.168.1.1/24 and link them together by a switch not sure thats a good idea.
no, actually I have a LAN with an IP range of 192.168.10.1 with a submask of 255.255.255.0, but I need more IPs.
you need to make the submask bigger
- 242 Nebula Ideas
- 6.8K Security
- 779 USG FLEX H Series
- 387 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 324 Service & License
- 527 News and Release
- 101 Security Advisories
- 5.3K FAQ
- 91 About Community
- 121 Security Highlight
