How to let the web ui of zywall only accessable by using only one domin zone
JiangNanGenius
How to set a limitation. To only use one domain zone like it.XXX.com instead accessible from all domain that binded with the IP-address
@JiangNanGenius
As I know, ZyWALL doesn't support reverse proxy(like nginx) to map to internal server by FQDN.
But I found a work-around that can use Content Filter function to limit only access the FQDN can access the mapped internal web server.
1. Go to UTM profile > Content Filter, create a profile.
- Enable the Custom Service
- Enable Allow web traffic for trusted web sited only
- Add the FQDN into the Trusted Web Sites list
2. Apply the Content Filter profile on the Security Policy for access the internal web server
Then, only the HTTP request to this FQDN can access the internal web server.
Other request will be blocked and get a denied message.
6
i'm using a zywall 1100
You can only grouping the FQDN objects (host1.it.xxx.com, host2.it.xxx.com, ...).
Wildcard(*.it.xxx.com) is not possible as source, since "*" means unknown.
@Ian31 Thanks a lot for your reply. But actually the problem is i cannot find the option0
Sorry, I think I misunderstood what you want.
Do you want to limit the source IP that can access the device GUI ?
or want to limit the device GUI binding FQDN ? (like a virtual host of web service)
@Ian31 Accutally i want to limit the device GUI binding FQDN. Like using nas.xxx.com to only my nas remote.
@JiangNanGenius
6 -
@Ian31 Thanks a lot it's working
- 439 Beta Program
- 191 Nebula Ideas
- 6.2K Security
- 468 USG FLEX H Series
- 308 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 441 News and Release
- 4.3K FAQ
- 93 Security Highlight
