Can I transfer configuration from USG FLEX series to USG FLEX H series?
FelippeSic
FelippeSic Posts: 5 image  Freshman Member
First Anniversary
I was wondering, is there any link or software to help you transfer information between a series of equipment?
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,319 image  Zyxel Employee
    Hi @FelippeSic ,
    You can convert your USG FLEX configuration to a USG FLEX H model configuration using the tool at
    convert.cloud.zyxel.com
    Please note that conversion is only possible between models of the same level (for example, from USG FLEX 200 to USG FLEX 200H or 200HP).
    Zyxel_Judy
    Untitled Image
