AP can't to connect nebula cloud
optimized
optimized Posts: 1 image  Freshman Member
status not connect but i check clock time incorrect current. i would like to change by command however this command reject please tell me command to change clock time.
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317 image  Zyxel Employee
    Hi @optimized ,
    You must use the configure terminal command to enter the configuration mode before you can use the command: ntp sync to get the time and date from a NTP time server.
    You can download the relevant CLI Reference Guide from the Zyxel Download Library.
    Download Library | Zyxel Networks
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Hi @optimized ,
    Zyxel_Judy
    Untitled Image
