L2TP VPN on USG FLEX H series??
Painted_Turtle
Painted_Turtle Posts: 13 image  Freshman Member
Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Switch Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula
Where does one configure a L2TP VPN?
Most of my customers have remote employees using L2TP VPN.
    PeterUK Posts: 4,415 image  Guru Member
    Yes sad and it means you have to pick the old models over the FLEX H
