Automatic Firewall config save to Nebula
Nowadays if I change something, I manually save roms of my clients(41 FLEX 200 models, 34 FLEX 100, 10 FLEX 50). I can choose to regurly send roms to an emailadress, but that will be a mess. Why no automatic save to Nebula of it's connected with Nebula? Even better would be that it automatically downloads the rom if replacing/upgrading the firewall.
Hi @nielsscheldeman,
Do you mean you want to save the configuration on Nebula? May I know what mode are your firewalls currently running?
Zyxel Melen0 -
Hello, at the moment they are running on premise. But I'm testing FLEX 200H which is connected to Nebula. Most of the config still has to be done on premise. It would be nice if that configfile is automatically saved to Nebula(or is it already?)
I apologize for the delayed reply.
The configuration won't automatically save to Nebula. Instead, you can use the schedule backup function to save the configuration on Nebula.
Zyxel Melen0
- 241 Nebula Ideas
- 6.8K Security
- 761 USG FLEX H Series
- 383 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 323 Service & License
- 522 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
