Problem with XGS1930-52 and DAC10G-1M
Venta
Venta Posts: 11 image  Freshman Member
Hallo,
i have tried to connect two XGS1930-52 Switches with a DAC10G-1M Direct Cable.
After doing the correct setting on the Port to DAC the connection was successful, but the speed is only 1G instead of 10G?
Any hints?
Thx
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,676 image  Zyxel Employee
    Hi @Venta,
    Could you set the link speed to 10G/Full Duplex on both switches to test first?
    Zyxel Melen
  • Venta
    Hallo,
    i have tried to set the Link speed to 10G/Full Duplex on one side, but it did not work.
    Do i have to set it on both sides?
    Thx
  • Zyxel_Melen
    Hi @Venta,
    Yes, please set the link speed to 10G/Full Duplex on both switches.
    Zyxel Melen
  • Zyxel_Melen
    Update:
    The reason for the auto-negotiation links to 1G is that Nebula pushes the wrong link speed configuration. This has been corrected, if anyone hasn't fixed your port to 10G, please change the port setting so Nebula will push the correct configuration to your device.
    Zyxel Melen
  • mMontana
    mMontana Posts: 1,469 image  Guru Member
    Well… According to this…
    Nebula service is built to asks the users to solve the things done wrong by Nebula team?
    I'd suggest to publish an advisory for that, both on community and nebula dashboard.
    If Zyxel is going "Cloud only" for the devices… I will quit buying zyxel devices and advise against buy it.
  • Zyxel_Melen
    Hi @mMontana,
    No. We decided not to push the correct configuration because, although it might be short, it could cause network downtime for other users.
    Thanks for your input. I have shared it with our product team.
    Zyxel Melen
