Geography does not work
webdisaster
webdisaster Posts: 8 image  Freshman Member
First Comment Sixth Anniversary
wantes to block access from outside austria for an external service.
adde d geo austria , made nat and securriy rule with source austria. Somerimes it work. Other times source is blocked and the block is logged
Log shows ,that the source comes from austria.
bit austria should be unblocked.
Removing geo give access to all and the service works
this problem exists at actual flex series (dont know if h series to) and on older usg. Thonk the problem exists since 4.38
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,613 image  Zyxel Employee
    Hi @webdisaster,
    What's the log when the access is blocked? And what's your full security policy list?
    Zyxel Melen
  • webdisaster
    edited February 2025
    Blocked with austrian flag at the end of the line. the strange thing is that sometimes it works
    added group GEO. addad austria to group
    made Firewall rule and NAT ( not representative - like i do every time on forwarding)
    wan to lan1 sourc. GEO dest. 192.168.110.253 (Obj. XPC) service 1001 (XPC-Service) allow
    Security Policy Control
    Match default rule, DROP
    x.x.x.x:53812
    192.168.110.253:1001
    If the other end uses a VPN then the rule will not apply
  • webdisaster
    yes its a vpn. Flex is a VPN Endpoint. want to secure it to specific country
    how does the other end and from where connect to this port 1001?
