flex100H IKEv2 with lan Radius server
Hi. I have an AD server with radius server on lan. I want to connect to flex100H with IKEv2 to the router with radius credentials. It just does not work. Can you help me?
Hi @AttilaZsedenyi,
You need to set your RADIUS server information on the H series first.
Then create the remote access VPN with RADIUS authentication.
Zyxel Melen0 -
Hi Melen.
This is all good but when I connect from the computer from wan with IKEv2/ipsec to to the router with radius/ad cedentials it does not let me to login. Thanks.
Hi @AttilaZsedenyi,
To better understand and investigate the issues you're experiencing, it would be helpful if we could access your firewall remotely via the web GUI.
You can follow the steps in this guide to enable HTTPS Web GUI access from the WAN:
How to allow HTTPS Web GUI Access from WAN? (USG FLEX H) — Zyxel Community
Once enabled, please share the login credentials for your device with us via a private message.
Zyxel Melen0
- 439 Beta Program
- 191 Nebula Ideas
- 6.2K Security
- 469 USG FLEX H Series
- 308 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 441 News and Release
- 4.3K FAQ
- 93 Security Highlight
