About set the DHCP relay on USG40
Hi @Shift
In your scenario, does DHCP server(140.111.111.106) is able ping to USG LAN interface IP address(192.168.100.254)?
If answer is not, then DHCP offer will unable pass to client successfully.
I guess your DHCP server is located on WAN side of USG.
Then you have to add a routing rule on your router.
e.g. Destination: 192.168.100.0/24, NextHop: 140.111.111.11
5
Hi @shift
Welcome to Zyxel community
Does your DHCP server is located in other subnet of USG40? Or other else?
Can you provide the topology of your DHCP environment? (IP subnets/ DHCP server/ DHCP clients…etc)
HI, Stanley:Here is my topolopy of my DHCP enviromentThe DHCP server and USG are at the same subnet...The DHCP client catn't get ip from DHCP server on Windows ServerAny suggestion? Thank you.0
Hi @Shift
5 -
Wa !I think your right, but I will check it later because I got another solution...Thank you again...0
Hi @dpipro
Just Enable “Enable Web Authentication” at “CONFIGURATION > Web Authentication > General tab”, and add Web Authentication policy for Lan users.
Incoming interface : Select the interface on which packets for this policy are received.
Source Address : Select a source address or address group.
Authentication Type : Default-web-portal: the default login page built into the Zyxel Device.
default-user-agreement: The default user agreement page built into the Zyxel Device
- 431 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 6K Security
- 385 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
