[Release Note] Zyxel Access Point - V7.00 Patch 2 firmware has been released (New info)
Access Points Firmware Release Note
August 2024
Overview
This document provides firmware release information on Zyxel Access Points platforms, introduce new Access Points, new features and enhancements, bug fix, known issues and workarounds information for Release V7.00 Patch 2 C0.
Supported Platforms
(Click Hyperlink to download the firmware directly)
WiFi 7 model(s):
Zyxel WBE660S - V7.00(ACGG.2)C0
Zyxel WBE530 - V7.00(ACLE.2)C0
Zyxel NWA130BE - V7.00(ACIL.2)C0
WiFi 6E model(s):
Zyxel WAX640S-6E - V7.00(ACCM.2)C0
Zyxel WAX620D-6E - V7.00(ACCN.2)C0
Zyxel NWA220AX-6E - V7.00(ACCO.2)C0
WiFi 6 model(s):
Zyxel WAX655E - V7.00(ACDO.2)C0
Zyxel WAX650S - V7.00(ABRM.2)C0
Zyxel WAX630S - V7.00(ABZD.2)C0
Zyxel WAX610D - V7.00(ABTE.2)C0
Zyxel WAX510D - V7.00(ABTF.2)C0
Zyxel WAX300H - V7.00(ACHF.2)C0
Zyxel NWA210AX - V7.00(ABTD.2)C0
Zyxel NWA110AX - V7.00(ABTG.2)C0
Zyxel NWA50AX PRO - V7.00(ACGE.2)C0
Zyxel NWA90AX PRO - V7.00(ACGF.2)C0
Zyxel NWA50AX - V7.00(ABYW.2)C0
Zyxel NWA55AXE - V7.00(ABZL.2)C0
Zyxel NWA90AX - V7.00(ACCV.2)C0
New Features and Enhancements
1. Enhanced stability with Multi-Link Operation (MLO) for Wi-Fi 7 models on Nebula Control Center.
Bug Fix
Bug fix | C | M | S |
1. [eITS: 240701802] Devices connect on NWA55AXE, NWA90AX of V 7.00P1 firmware cannot show the captive portal for Voucher when SSID enables Guest Network and NAT mode with Voucher sign-in method | V | - | - |
2. [Vulnerability] Fix CVE-2024-3596 | V | V | V |
3. [Vulnerability] Fix CVE-2024-7261 | V | V | V |
Known Issue
Known Issue | C | M | S |
1. [eITS: 240600705] NWA130BE created multiple SSID. When station connected on same Bug fix Cloud Managed Standalone SSID cannot ping to each. | V | V | V |
2. [eITS: 240500161] NWA130BE change uplink port rate to 1G from 5G will cause ethernet high ping latency | V | V | V |
3. [eITS: 240600783] Without wireless bridge function LAN port still could be used | V | - | - |
4. [eITS: 240300941] Invalid character for password message after Certificate importing | - | - | V |
5. [eITS: 240700123] AP call home Nebula fail | V | - | - |
6. [eITS: 240501455] WiFi 7 products are more susceptible to interference | V | V | V |
Limitation of Settings
N/A
Found a kind of stupid visual bug in the device webif of our WAX650S… maybe in other models too.
Monitor → Station Info → click sort with the Association Time column.
It sorts the client list alphabetically, not by date/time. Note that the date/time column is formatted to European standard.Slightly annoying when debugging client connection issues.
Yes… issue is still there in version 7.10 - still does not sort by date/time. Next to that… the date time format itself is US American, even though the model we have is EU.
One could expect that the web interface reads regional info from the webbrowser, but is does not. In fact, we also cannot set the country code (802.11d) from the web interface as well.
I hope that all these bugs can be fixed with the next update.
- 439 Beta Program
- 191 Nebula Ideas
- 6.2K Security
- 469 USG FLEX H Series
- 308 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 441 News and Release
- 4.3K FAQ
- 93 Security Highlight
