usg flex 200hp how can I convert wan port to lan port for ZyXEL WBE660S
Don_Eduardo1969
Don_Eduardo1969 Posts: 1 image  Freshman Member
Sixth Anniversary
usg flex 200hp how can I convert wan p2 port to lan port for ZyXEL WBE660S
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,600 image  Zyxel Employee
    Hi @Don_Eduardo1969,
    You need to remove p2 from the ge2/WAN2 interface and then add p2 to the lan interface, default name is ge3.
    In addition, you will need to connect the power adopter since 200HP only supports AT, which might cause WiFi restrictions.
    Zyxel Melen
  • Zyxel_Melen
    Zyxel Melen
