Indeed Website not displaying properly.
For some reason the indeed website does not work properly. I have whitelisted the site and it did not change anything. All other sites appear to work correctly. I have attached a file with the first screenshot showing what the website should look like and three other screenshots showing various pages on the indeed site.
This happens on all PCs, wireless and wired. Also happens with various broswers (Edge, Chrome & Firefox).
Attaching the PC to a hotspot allows the site to load properly.
Larry
Hi @laltobelli ,
It looks like the webpage may be blocked by the Content Filter function. There are several trusted websites in your configuration file:
indeed.com
secure.indeed.com
www.indeed.com
emloyers.indeed.comThere may still be some images or web pages that are not in the current list. You can trust a wildcard URL as *.indeed.com
If the problem persists, please check if there are any blocked logs in the log. And then, you can manually add them.
Zyxel_Judy
Sorry I am using a USG Flex 200, firmware V5.39(ABUI.1).
Hi @laltobelli ,
Could you try opening the link after clearing your cache and history? Alternatively, you could try opening the link in a private browser window.
If the symptom still recurs, please download USG FLEX 200's diagnostic file and share with us. The path to download: Maintenance > Diagnostic
Zyxel_Judy
Already tried to clear cache & history and tried it in a private browser, but tried it again and still had the same problem.
I have attached the diagnostic file. Had to change the file name from diaginfo-2025-02-11_22-34-29-tar.bz2 to
diaginfo-2025-02-11_22-34-29-tar.gz in order to upload. You may have to rename it back.
Any progress with the diagnostic file?
Hi @laltobelli ,
indeed.com
secure.indeed.com
www.indeed.com
Zyxel_Judy
Thank you. Adding *.indeed.com to the list did solve the problem.
- 222 Nebula Ideas
- 616 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
