Indeed Website not displaying properly.
laltobelli
laltobelli Posts: 24 image  Freshman Member
First Comment Sixth Anniversary
For some reason the indeed website does not work properly. I have whitelisted the site and it did not change anything. All other sites appear to work correctly. I have attached a file with the first screenshot showing what the website should look like and three other screenshots showing various pages on the indeed site.
This happens on all PCs, wireless and wired. Also happens with various broswers (Edge, Chrome & Firefox).
Attaching the PC to a hotspot allows the site to load properly.
Larry
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,315 image  Zyxel Employee
    Hi @laltobelli ,
    It looks like the webpage may be blocked by the Content Filter function. There are several trusted websites in your configuration file:
    indeed.com
    secure.indeed.com
    www.indeed.com
    emloyers.indeed.com
    There may still be some images or web pages that are not in the current list. You can trust a wildcard URL as *.indeed.com
    If the problem persists, please check if there are any blocked logs in the log. And then, you can manually add them.
    Zyxel_Judy
    Untitled Image
  • laltobelli
    Sorry I am using a USG Flex 200, firmware V5.39(ABUI.1).
  • Zyxel_Judy
    Hi @laltobelli ,
    Could you try opening the link after clearing your cache and history? Alternatively, you could try opening the link in a private browser window.
    If the symptom still recurs, please download USG FLEX 200's diagnostic file and share with us. The path to download: Maintenance > Diagnostic
    Zyxel_Judy
    Untitled Image
  • laltobelli
    Already tried to clear cache & history and tried it in a private browser, but tried it again and still had the same problem.
    I have attached the diagnostic file. Had to change the file name from diaginfo-2025-02-11_22-34-29-tar.bz2 to
    diaginfo-2025-02-11_22-34-29-tar.gz in order to upload. You may have to rename it back.
  • laltobelli
    Any progress with the diagnostic file?
  • Zyxel_Judy
    Hi @laltobelli ,
    indeed.com
    secure.indeed.com
    www.indeed.com
    emloyers.indeed.com
    Zyxel_Judy
    Untitled Image
  • laltobelli
    Thank you. Adding *.indeed.com to the list did solve the problem.
