Zywall 110 Throughput
rookierunner
in Security
What should I expect as throughput from my Zywall 110 device? I know that it depends on what is enabled as services. What is the max throughput without anything enabled beyond security policies and ADP?
Here you can find the specs:
The SPI firewall throughput is not TCP based the speed also depend on the CPU core that a TCP session is linked to not sure how its managed but you would need a download thread count of about 4 to really max to Zywall 110 out.
Thanks for the information. After troubleshooting, I figured out that my cable modem was the limiting factor on the throughput. Swapped it out and all is good again.
- 601 USG FLEX H Series
- 480 News and Release
