USG60 config to Flex 100, how to proceed?
we used to have a USG60 of which I have a backup startup-config.conf
Now I have a Zywall Flex 100 with a forgotten password, and would like to use the backup on it. Will probably reset and try to upload the backup. Not sure about the firmware version.
How do I do it? Do I need to convert it somehow, or is it already compatible?
! saved at 2022-05-27 13:36:55
! model: USG60
! firmware version: 4.72(AAKY.0)
Thank you for any insight.
Hi @Gleith,
You can't import the configuration from USG60 to USG FLEX 100 directly since:
- Model and firmware version mismatch.
- The suggested migration device is the USG FLEX 200.
For these reasons, you need to manually configure the USG FLEX 100.
Zyxel Melen0
Hi @Gleith,
Zyxel Melen0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 299 Service & License
- 482 News and Release
