bandwidth is invalid when changing WAN interface from DHCP to static IP
GRCSS
GRCSS Posts: 2 image  Freshman Member
zyxel usg 100 'There were errors in inputting this configuration: Downstream bandwidth is invalid. Upstream bandwidth is invalid.'
  • GRCSS
    Hi Zyxel_Judy
    Zyxel released a patch which rectified the issue.
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317 image  Zyxel Employee
    Hi @GRCSS ,
    To help us better assist you, please provide:
    1. The full model's name
    2. Your current firmware version
    3. Screenshots showing both the error message and the menu where it appears
    Zyxel_Judy
    Untitled Image
  • GRCSS
    Hi Zyxel_Judy
