ZyWall USG60: VPN IKEv2 Connection using Windows 11?
Hello @PeterUK (and anyone else willing to reply) in your opion is actually possible to configure an IPSec VPN IKEv2 with PSK on Windows 10/11 using the native Windows client? Do you have knowledge of any other freeware client? I there is no option for PSK, in case of certificate how do you manage multiple VPN configurations on the same client (and multiple certificates? I mean, how is Windows able to understand which is the correct certificate to be used?
There is not option for IKEv2 with PSK in windows that I know of.
When you setup a IKEv2 with certificate its just the one certificate you need to install on clients which if self signed certificate needs to be imported to mmc.exe to Trusted root certification authorities
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
