VPN full tunnel + thetering
Hi folks.
Scenario: android smartphone connected to an IPSec client to Site VPN IKEv2 with certificate. the VPN is full tunnel, the VPN client is Strongswan. Windows pc connected in thetering to the android smartphone.
Why the traffic created by the Windows pc does not enter the tunnel? Is there a way to force it?
Hi @QuiteSmart,
So, does your Windows PC not have another Internet link in this scenario?
What's your Windows PC's routing table?
Zyxel Melen0 -
This it due to the way thetering is handled so you need to setup VPN on the PC
I tried the same as @QuiteSmart some time ago, but it didn't work.
It should not be Windows routing table: when you use tether, Smartphone is default gateway.
The issue is that Android, when "tethering", routes traffic from clients only to WAN interface. Not to tunnel one.
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
