Which of the following rank is Zyxel Networks Security Gateway chosen best-in-breed for SMB under 10
Are you looking for Zyxel Networks Security Gateways suitable for SMBs with fewer than 10 employees?
If you need wireless functionality (Wi-Fi) with your security appliance, we recommend the USG FLEX 100AX. If you don't require wireless functionality, the USG FLEX 100 would be suitable for your needs.
If you would like to have specific requirements, to better assist you, could you share more details about your requirements such as:
- Which security services are you interested in using?
- How many WAN and LAN ports do you require?
- What is your network scenario?…
The more detailed requirements you share, the more accurately we can recommend a suitable model for your needs.
Zyxel_Judy
Zyxel_Judy
- 441 Beta Program
- 293 Service & License
