ZyWall USG60: VPN IKEv2 Connection using Windows 11?
2»
  • QuiteSmart
    QuiteSmart Posts: 68 image  Ally Member
    Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch Zyxel Certified Network Administrator - WLAN
    Hello @PeterUK (and anyone else willing to reply) in your opion is actually possible to configure an IPSec VPN IKEv2 with PSK on Windows 10/11 using the native Windows client? Do you have knowledge of any other freeware client? I there is no option for PSK, in case of certificate how do you manage multiple VPN configurations on the same client (and multiple certificates? I mean, how is Windows able to understand which is the correct certificate to be used?
    PeterUK Posts: 4,446 image  Guru Member
    edited February 2025
    There is not option for IKEv2 with PSK in windows that I know of.
    When you setup a IKEv2 with certificate its just the one certificate you need to install on clients which if self signed certificate needs to be imported to mmc.exe to Trusted root certification authorities
    How to Import Intermediate and Root Certificates using MMC
