USGFLEX100H 2FA OpenVPN
andrealemmi
andrealemmi Posts: 12 image  Freshman Member
First Comment Seventh Anniversary Nebula Gratitude
Good evening,is 2 factor authentication supported on a usgflex100h using vpnssl via openssl (via email or google authenticator)? If I configure client access on the vpnssl as a split tunnel for a subnet, the remote client is unable to navigate, do I need to create policy routes on the firewall?
Thank you.
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,316 image  Zyxel Employee
    Hi @andrealemmi ,
    To better assist you, please clarify the below items:
    I notice you mentioned OpenVPN in the title but OpenSSL in the content. Could you clarify which one you are trying to use?
    Could you provide more details about your configuration and the symptoms you're experiencing?
    Zyxel_Judy
    Untitled Image
    So you need to allow from SSL zone to Zywall and the IP of 2FA is the LAN gateway IP of the split tunnel subnet.
