FWA710 5G router.
I´m having trouble to get 710 to work with a GS1915 and VLAN.
Can I set up VLAN with dhcp on the 710 or do I have to use another hardware for that, and if so how do i set up the 710?
Another question,
When I set up the 710 with a static ip (192.168.1.1). When i connect a computer to it, it passes a 10.29.xxx.xxx adress. Is this becouse of the passtrough?
Kind regards
Richard
Hi @TelexRich,
About the first question, could you share your topology and the network scenario with us first? Normally, you need to set the connection port to FWA710 as a tagged member for a specific VLAN.
About the second question, it seems like you are under IP passthrough mode. You need to disable it first.
[Mobile router] How to change FWA710 to IP passthrough mode? — Zyxel Community
Zyxel Melen0 -
- 434 Beta Program
- 2.6K Nebula
- 172 Nebula Ideas
- 404 USG FLEX H Series
- 296 Security Ideas
- 43 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 4K FAQ
- 83 Security Highlight
