SFP+ Compatibility
Ololo
Ololo Posts: 1 image  Freshman Member
Hi there.
Is the Intel(R) Ethernet Connection X722 for 10GbE SFP+ compatible to XGS1935-52 with 4 SFP+?
Best regards, Ololo
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,615 image  Zyxel Employee
    edited February 2025
    Hi @Ololo,
    Intel(R) Ethernet Connection X722 supports 10GBASE-SR and 10GBASE-LR which are supported by the XGS1935 series. Therefore, they should be compatible.
    May I know if you encounter any IOP issues? If so, which transceiver are you using?
    In addition, ZYXEL switch products are recommended to be used exclusively with ZYXEL brand modules to ensure optimal performance and reliability.
    Using modules from third-party sources can potentially lead to decreased network performance and reliability, such as packet loss and connectivity issues, which also cannot be guaranteed by ZYXEL. ZYXEL may not offer technical support for networking issues that are identified as being caused by IOP with third-party modules.
    Zyxel Melen
