IKEv2 Connection Fail under some connectivity.
WDC
WDC Posts: 1 image  Freshman Member
Hi dear i configured a RoadWarrior ikev2 wih my flex 500 but sometimes it fail the connection using different wisp… some time it works some time no… i tryed to enable ikev2 frammentation on windows (using the windows native client).
How to improve the configuration?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,244 image  Zyxel Employee
    Hi @WDC,
    What kind of logs did the device print when you encountered the failed connection issue?
    Zyxel Melen
