USG FLEX 500H - SNAT on a Site-2-Site VPN
Hi
I want to replace a Cisco ASA 5506-x with a USG FLEX 500H. I have multiple Site-2-Site VPN connections and and got them all but one up and running. The last one uses SNAT, where my lan subnet (/24) has to be translated to another (/32).
All information I could find so for on SNAT in a VPN tunnel is for the old model, or a single article mentioning that this should be supported from firmware version released in April 2024.
So has anyone set this up, and can guide me how to do it?
No SNAT for VPN Site-2-Site not yet implemented in H models
Oh good they added it 😀
Been having a hard time getting into my FLEX H due to every 24hr or so I can't login and needs a reboot still waiting on a update for a fix on this.😶
Edit
so looks like they only added outbound NAT which I guess most only need
Hi @zyman2008
Thanks a lot. I have no access to the firewall at the moment, but I will check if I got the newest firmware, because I don't think I saw this option earlier. Will return when I had the chance.0
- 441 Beta Program
- 293 Service & License
