USG FLEX 500H - SNAT on a Site-2-Site VPN
NHC
NHC Posts: 5 image  Freshman Member
Hi
I want to replace a Cisco ASA 5506-x with a USG FLEX 500H. I have multiple Site-2-Site VPN connections and and got them all but one up and running. The last one uses SNAT, where my lan subnet (/24) has to be translated to another (/32).
All information I could find so for on SNAT in a VPN tunnel is for the old model, or a single article mentioning that this should be supported from firmware version released in April 2024.
So has anyone set this up, and can guide me how to do it?
  • zyman2008
    zyman2008 Posts: 241 image  Master Member
    50 Answers First Comment Friend Collector Eighth Anniversary
    Hi @NHC ,
    With version 1.31, in the advanced settings under the phase 2 section.
    PeterUK Posts: 4,264 image  Guru Member
    edited February 25
    No SNAT for VPN Site-2-Site not yet implemented in H models
  • zyman2008
    Hi @NHC ,
    edited February 27
    Oh good they added it 😀
    Been having a hard time getting into my FLEX H due to every 24hr or so I can't login and needs a reboot still waiting on a update for a fix on this.😶
    Edit
    so looks like they only added outbound NAT which I guess most only need
  • NHC
    Hi @zyman2008
    Thanks a lot. I have no access to the firewall at the moment, but I will check if I got the newest firmware, because I don't think I saw this option earlier. Will return when I had the chance.
