SFP Slot at USG 700 Flex - which standard is supported?
USG_User
USG_User Posts: 400 image  Master Member
Which SFP standard support the SFP ports on USG 700 FLEX? The problem is, that we most probably get only one single fiber and have to put dual wave length for TX and RX on it. But this would be 1000BASE-BX standard. Many devices on the market only support 1000BASE-SX /-LX /-ZX standards where different fibers are in use for TX and RX traffic.
Unfortunately tis detail is not described in the user manual or technical specification.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,604 image  Zyxel Employee
    Hi @USG_User,
    Please reference the device's datasheet:
    In addition, USG FLEX 700 doesn't support 10G link speed. Please ignore the 10G SFP+ modules.
    Zyxel Melen
  • Zyxel_Melen
    Hi @USG_User,
    Zyxel Melen
  • USG_User
    Thanks a lot Melen,
    nice to see that USG Flex 700 supports BX standard.
