V1.31 not stable to the UI
    PeterUK Posts: 3,983  Guru Member
    edited January 23
    Good hope it fixes my issue too @Mk88_it
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,697  Zyxel Employee
    Hi @PeterUK,
    We released a new date code firmware for this issue. I will send it to you via private message. Please help to check your message box.
    Zyxel Melen
    Thanks installed now will monitor over a week but should see if its fix in the next 48hr
  • Mk88_it
    Mk88_it Posts: 68  Ally Member
    I just installed the same firmware
    Sorry to report this did not fix the problem.
  • Mk88_it
    @Zyxel_Melen in my case, no more errors were displayed in the gui after 7 days of uptime
  • Zyxel_Melen
    Hi @Mk88_it,
    Thanks for your update~ 🤗
    However, we will keep checking with PeterUK about this issue.
    Zyxel Melen
    When you left the error now currently shows
  • Mk88_it
    @PeterUK We are in the same boat. @Zyxel_Melen The errors reappeared with ITS0310 firmware
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317  Zyxel Employee
    Hi users,
    The firmware version 1.32P0, that includes the solution, has been released today.
    Please download the latest firmware version and upgrade your device. If you encounter any issues after upgrading, kindly create a new post so we can track problems specifically related to the 1.32 firmware version.
    Zyxel_Judy
    Untitled Image
