USG FlexH500 HA / VPN Ike2 Cert
Posts: 126  Ally Member
5 Answers First Comment Friend Collector Fourth Anniversary
Hi everyone, I need to setup a client-to-site ike2 VPN with a self-signed certificate on a pair of Flex 500H in HA. My question: What happens to the certificate when failover occurs? Will external clients continue to connect? Or not?
Thanks in advance
Lorenzo
Welcome!
It looks like you're new here. If you want to get involved, click on this button!
  • Posts: 3,176  Zyxel Employee
    Hi @Fred_77,
    I apologize for my miss that I didn't reply to your comment.
    For the license issue, I will send you a private message for the org access and the device MAC address to check this issue.
    Zyxel Melen
    Hi @Fred_77,
    When you import, the certificate is applied to the HA master and slave. Therefore, the remote access VPN client's connection should not be affected.
    May I know if you encountered any issues in this scenario?
    Zyxel Melen
  • Posts: 126  Ally Member
    Hi @Zyxel_Melen ,
    Yesterday we had a test session on devices. This is what we did:
    Flex500H-01 and Flex500H-02: directly connected to the ISP router (Ge1)
    Lan1 (Ge5) connected to our MGMT laptop.
    Flex500H-01
    Wizard first run, joined to customer's nebula org in HQ-Site.
    Just few changes from default configuration.
    Interfaces:
    Wan ip x.y.z.76/28
    Wan gw x.y.z.65/28
    Lan1 IP 192.168.168.1
    Lan2 IP 192.168.169.250
    System=>Settings
    Https port 9443
    System=>Certificate
    Created a new self signed cert.
    Object=>User&Auth=>Users/Group:
    Created a user to test vpn
    VPN=>IPSec=>Remote Access:
    Configured a client to site VPN IKE2 with cert.
    Flex500H-02
    Wizard first run, joined to customer's nebula org in "Temp-Site".
    Interfaces:
    Wan ip x.y.z.75/28
    Wan gw x.y.z.65/28
    System=>Settings
    Https port 9443
    No other config made.
    Both devices run latest firmware, same license/signature
    So far, so good.
    Enabled HA on Flex500H-01 as primary,
    active ip 10.10.10.4/24
    passive ip 10.10.10.5/24
    monitored interface Ge1 (only link down)
    Enabled Ha on Flex500H-02 as secondary
    Linked devices via HB on port 12.
    As expected secondary device removed from Temp-Site (still visible in inventory on NCC), all ports disabled except HB, responding at 10.10.10.5
    On active device everything "SEEMS" ok: devices paired and license expiration date postponed by one year.
    But good news end here.
    Active device reports "Sync fail"; passive device kept it's own configuration.
    Tryed anyway faiover unplugging ge1 on active device.
    After 5 sec. devices swapped role (but not the configuration).
    Reconnected ge1 on "now-passive" device, waited a while, and unplugged ge1 on active device.
    I would have expected another role swap and instead...
    BOOOM
    both devices unreachable not responding to ping.
    Only solution, turn off both devices and turn them on one at a time.
    Primary (Active) device reports HA status "paired"; "none" as last sync; and ALL LICENCES EXPIRED!
    As a final test, I tried to force sync with cli in the web console, to no avail. Still "sync failed".
    Discouraged, I stopped testing.
    Thanks in advance for any suggestions
    Lorenzo
    Hi all,
    Update
    i did several tests and after a non-sense sequence (IMHO), HA works as expectec.
    I had to:
    disable SSH and FTP
    Reboot
    enable SSH and FTP
    Reboot
    Note that the same sequence without 2 restarts did non fix the problem.
    I can now force a manual full sync successfully.
    Licenses still expired.
    Thanks in advance
    Lorenzo
    Hi @Fred_77,
    Zyxel Melen
Welcome!
Welcome!
