usg20-vpn and surfshark
Slepland
Slepland Posts: 1 image  Freshman Member
is there anybody able to share a configuration to connect my old usg20-vpn with surfshark?
Actually looks like they provide a certificate for an ikev2 that i cannot import because they provide no secret key with it, and also no shared key.
I think i should use the username and password system through ms chap, but it seems it cannot work :(
    PeterUK Posts: 4,174 image  Guru Member
    You can't connect to that VPN use case
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,043 image  Zyxel Employee
    Hi @Slepland,
    USG20-VPN doesn't support this VPN scenario.
    Zyxel Melen
