Just to Verify
Dpj
Dpj Posts: 213 image  Master Member
Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security First Comment Friend Collector
Yesterday i visited an customer with wireless issues.
In the logging i found this:
Disable slot3 due to limited power
the same with slot 1 and 22.
So i replaced an old switch for a new POE switch, and the issues was solved. But what means slot3, 2 and 1?
I checked chatgpt, and it gave me this result:
The Zyxel NWA130BE is a Wi-Fi 6E access point, which means it operates on three frequency bands:
  • Slot1 → 2.4 GHz Radio
  • Slot2 → 5 GHz Radio
  • Slot3 → 6 GHz Radio (Wi-Fi 6E)
is this correct??
it feels logic, but prefer to get the anwer here.
yours Dennis
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,611 image  Zyxel Employee
    Hi @Dpj,
    Yes, NWA130BE is a WiFi 7 tri-radio AP. The slot-radio relationship you get from chat GPT is correct.
    Zyxel Melen
  • Zyxel_Melen
    Hi @Dpj,
    Zyxel Melen
