USG310 - blocking ip from file
Hi @Przemek
In 4.35 will support location by continental in GeoIP.(Africa/ Europ/ Oceania….etc)
If your area is small than continental, then add address group by country will much fulfill your requirement.
5
Hi @Przemek
Welcome to Zyxel community.
Currently USG doesn’t support add IP address object by importing the file.
And GeoIP doesn’t support IP object by regions(city).
I will add it into idea section.
I meant regions like this to block bigger areas without input countries one by one.
Many companies working on local or on few surrounding countries area and it can be useful to setup some firewall rules faster.0 -
Hi @Przemek
5 -
Hello, it would be a good idea to be able to import ips or ranges, etc ... from the object option, from a csv file
You can predefine address object on text file and paste all content in CLI mode. This is easier than Web gui operation.
e.g
address-object test 192.168.1.10
address-object test1 192.168.1.20
address-object test2 192.168.1.30
address-object test3 192.168.1.40
copy all contents and paste all in CLI.
- 441 Beta Program
- 292 Service & License
