Building a home Lab
Hi @kade
Welcome to Zyxel community.
For change LAN1 interface setting, there are IP address and default DHCP Pool have to changed.
a. LAN1 Interface IP address:
Router(config)# interface lan1
Router(config-if-lan1)# ip address 192.168.X.1 255.255.255.0
Router(config-if-lan1)# exit
Router(config)# write
b. LAN1 DHCP server:
Router(config)# ip dhcp pool LAN1_POOL
Router(config-ip-dhcp-pool)# network 192.168.X.0/24
Router(config-ip-dhcp-pool)# default-router 192.168.X.1
Router(config-ip-dhcp-pool)# starting-address 192.168.X.33 pool-size 200
Router(config-ip-dhcp-pool)# lease 2 0 0
Router(config-ip-dhcp-pool)# exit
For change hostname:
Router(config)# hostname ZYXEL_USG20-VPN
5
Hi @kade
5 -
Thanks you for your explanation, it does look little different from Cisco routers.0
- 240 Nebula Ideas
- 6.8K Security
- 755 USG FLEX H Series
- 379 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 320 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
