GS1920-24HP new password not accepted
accurro
accurro Posts: 29 image  Freshman Member
First Comment Nebula Gratitude Fourth Anniversary
edited August 2022 in Switch
Hi
have a GS1920-24HP on the latest fw 4.50 and factory reset
takes the default password but if you change the password it accepts the change and does the usual of telling you to close browser window and login in again, however after this it never accepts the new password.
have tried a number of the other config changes and these hold.
to test i saved the config before changing password so i can simple pull the power to get back to admin / 1234 and whatever password i put in it wont accept it or the default until the power cycle.
  • Zyxel_Lucious
    Zyxel_Lucious Posts: 283 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Nebula 25 Answers
    edited April 2019
    Hi @accurro
    Welcome to the Zyxel community!
    For starters, we wonder what browser (and what version) you are using?
    We've locally tested with IE 11.472.17134 / Chrome 73.0.3683.103, it turns out Chrome does have "new password login" issue as you mentioned but IE is immune.
    The problem seems to relate to cache mechanism of the browser, especially in recent ones.
    After we clear the cache on Chrome, we can successfully login with new password.
    So please clear your cache on browser after changing password to see if the problem resolves.
    In other way, you may also try access your switch via telnet/SSH. If you can login with the new password, it'd be
    self-explanatory that this is a browser issue instead of switch issue.
    Sincerely,
    Zyxel_Lucious
  • accurro
    Hi Lucious
    i am using chrome (latest version) but not saving the password with chrome
    will do a full cache clear after changing the password and see it that fixes it
    thanks
