ZyWALL 110, GS1900-24E and GS1200-8E vlan setup
JoseJones
JoseJones Posts: 1 image  Freshman Member
edited August 2022 in Switch
I'm looking to create some vlans to separate all these Internet of Things from our home network. It's not clear to me where I should originate the vlans or do I set up the same vlans on all devices? In reading the switch manuals they are the specific to the switch but don't mention how the ZyWALL fits in and vice versa.
For example I have a couple GS1200s that will have a few devices directly plugged in and many devices that connect via APs I'll have plugged into the GS1200 as well.
Device I want to isolate -> Isolated AP ->GS1200 -> GS1900 - ZyWALL 110
  • accurro
    accurro Posts: 29
    First Comment Nebula Gratitude Fourth Anniversary
    I would create the VLANs on the Zywall and then propagate down the network from there. The zyxel will then control the routing and access between vlans if needed.
  • xerox
    xerox Posts: 6
    Can you share the information of full network topology that you want to implement? What kind of the connection will be connected to GS1200?
