Why does my access point show orange status?
JonA
JonA Posts: 5  Freshman Member
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,209  Zyxel Employee
    Hi @JonA,
    Please describe more details about your question. Do you mean the AP LED or anything else? If is related to any web GUI, please also share the screenshot with us.
    Zyxel Melen
  • JonA
    Apologies for my lack of clarity, in the nebula control centre my NWA50AX PRO access point is showing a status in orange. When I look into the device the uplink is only showing 10/100mbps link speed. This device is hardwired from a TP Link PoE switch.
    PeterUK Posts: 3,770  Guru Member
    Maybe you have a bad cable run?
  • JonA
    Thanks. That was my first thought but its a new cable install and had the electrician test it twice. Its hard wired into a TP Link PoE switch, everything else connected works a full speed.
    I suggest bring the AP to the PoE and test with a short cable to be sure.
    I take it the TP Link PoE switch is 1Gb?
  • JonA
    That's a very good idea thank you and one that I have overlooked. I've tried swapping everything else around but not that. I guess if that works then it must the cable install.
    Yes, its a 5 port gigabit switch
  • Zyxel_Melen
    Hi @JonA,
    The orange status is because your AP has alerts. You can hover the mouse over the icon to find the problem. Based on the information you provided, this is because the uplink is 10/100Mbps.
    Please check if your switch only supports 100Mbps. If not, please try to change a cable or a switch port to check this issue.
    Zyxel Melen
