What type of MLO does NWA130BE support?
davidfi01
davidfi01 Posts: 25  Freshman Member
First Comment First Answer First Anniversary
Per Intel, there are various MLO capabilities that an AP may support:
Which type is supported on NWA130BE? based on generic test perfromance results I see, it is limited to EMLSR. Can someone at Zyxel please confirm?
D
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,430  Zyxel Employee
    Hi @davidfi01,
    I’m reaching out to our engineer about this question. While I do that, I’d love to hear how you tested and came to this conclusion. Could you share your insights with me?
    Zyxel Melen
  • davidfi01
    I used the Intel BE200 device manager config settings and windows wifi settings. In windows, I could confirm the number of MLO channels and WIFI 7 or BE connection (i.e. not AX). I used the driver settings to force either 6ghz or 5+6 ghz channel selection, and used corresponding radio settings on Nebula to confirm either MLO (5&6 ghz) or just 6Ghz connections. I can see that the unit connected using WIFI 7 or BE when MLO was on or off. I ran speed tests. There was little or NO difference in repeated speed tests between Wifi 7 or BE (when MLO was off). This indicates that the AP's are EMLSR, capable of listening on multi channel, but Tx/Rx on only one. That is why I am asking for clarification.
  • Zyxel_Melen
    Hi @davidfi01,
    Let me update you this first:
    Our engineer reports to me that NWA130BE's MLO capability is STR MLMR.
    Zyxel Melen
  • davidfi01
    Thanks - still don't know why download speed is approximately 1/2 of upload speed.
